jdamach1
Jim, here is a quick one that I took right after I pulled the hardtop, before the roll bar and softtop install. The 2.5" WH suspension was fresh at this point. It has settled just a bit since then.
![DSC01536.jpg](http://i423.photobucket.com/albums/pp320/jdamach1/1970%20Bronco/DSC01536.jpg)
Absolutely!
Shocks can make a huge difference, or none at all, depending on what you have and what you go to. But at the very least, reverting to one shock only can make a huge difference. Especially if the shocks you have were not designed (as in, valved) originaly as duals.
Duals just means twice as stiff if they're the wrong shock.
What other suspension mods do you have jb? It all works as a system, so many things can make an improvement. If it's an old system you have, chances are even changing out to new stuff would be an improvement, as old stuff tends to get stiff in the joints, so to speak.
Don't ask me how I know that last bit.
With the WH system 3, 2.5" lift is it necessary to get new or adjustable trac-bar?
There seems to be a big difference in parts between the WH system 3 and the JBC 2.5 Ultra Deluxe kit. Are some of the JBC parts unnecessary just to install this mild lift?
Jim
