2 Bad Horns in a Row
T-7ToNewOldB
Got a horn from Wild Horses. Tested on a battery. Worked great. Installed it and it wouldn’t work. Tested voltage at horn (good) tested ground at horn (good) jumped ground to battery (still didn’t work). Removed horn from the truck and tested directly to the battery no sound (yes I tested the battery) so bad horn.
WildHorses sent me a replacement, as always very easy to work with thanks Justin!.
Odd thing. Exact same cycle happened again. So something I’m doing is killing the horn. Can’t figure out what.
Both horns tested directly to the battery and worked when I started and both would not work when I finished. I’m a horn killer.
This is the horn.
https://www.wildhorses4x4.com/product/Horn_73-77_OEM/earlybroncomoreelectrical
T
T-7ToNewOldB
If this was my 53 Chevy I would be wondering if I bought a 6volt horn. Forgot that once and bought a battery based on what OReily’s comp said I should get. Installed it and wondered why the starter wouldn’t turn over and the battery was only at 6 volts. So said S**t and was about to return it to OReily’s as a bad battery. Cue slowly turning gears in my head that thankfully figured it out before I went back complaining that a 6 volt battery was only holding 6.3volts.
73azbronco
70s Caddy Eldo 4 note horn set, you will not be disappointed
Strange one T-7. Never seen that before. Plenty of times a horn won't work when connected for one reason or another, but those reasons are usually related to the wiring and not the horn itself.
But testing it working, then testing the same way and not working? Never heard that one.
What happens if you tap on them a bit with something metal (to get a good ringing vibration through the bell) and then try them again while grounded to the battery?
Normally I say leave the adjuster alone on a new horn, but now might be the time to try it. Turn it a quarter turn one way, then back to the starting point. See what happens.
And maybe the paint/coating on the bracket is too resistant to grounding effectively? Never heard of that either, but hey, you never know.
Good luck. Might just be crappy parts even though I'm pretty sure we have not had the issue with horns before. But then, not being in the building every day I might have missed some recent instances.
Keep trying...
paul
T
T-7ToNewOldB
Traveling for the week. I’ll give it a shot when I return. I agree having two of these do it is very unlikely.
Hugh
bax
Old Member
Well that "Blows".
Someone had to say it.
Ratclge
horn problem
I made sure mine had a paintless area under the mount point,worked ok.
T
T-7ToNewOldB
It does blow, sadly. Not making sound I get, bad power or bad ground. But 2 dying after a single honk? I’ll play around more when I get back in town. Gut says I’m missing something simple, reality seems to be disagreeing so far. I ground down to bare metal on the mounting point and I show zero ohms testing from the horn ground (on the horn itself) to the body, the engine, the frame and the negative terminal on the truck. Whole thing is well grounded really.
tody
happened to me, too. with a new horn from TBP.
started playing with the adjuster screw, came back to life that way.
Sounds like we're falling prey to the Chinese Scourge of auto parts again then. Playing with the screw is a time-honored fix for stuck horns, but it's usually on an old horn that's been sitting for decades in a back yard or barn that it's needed. Not on a new part.
I wonder if these have been sitting in a shipping container in Shanghai from a previous attempt to import them but they got sent back for improper labeling or some other such crap.
That's good to know if happened to you to Tody. Sorry to hear of course, but glad you chimed in with your experience.
T
T-7ToNewOldB
The one screw on the back. Is that the adjustment screw or the ground location? I thought it was a ground location. You can see where that led me. . . New build ground up so I don’t have anything to copy here.
ransil
its the adjustment,
Ground is done thru the mounting hole or drilling your own on the bracket part not the body.
T
T-7ToNewOldB
its the adjustment,
Thanks. my mistake. Super simple but couldn’t find instructions. Just assumed in was a ground screw. Been moving them in and out different positions but horn won’t honk. Can taking these out and put them back in ruin the horn or do I just have to find the right position?
The screw does have just the right position of adjustment to get it to work properly, but I don't know if removing one completely would do harm. I would not think so, but if it's actually attached to the diaphragm somehow, then it's very possible.
And if they're going to work at all, there is a range of movement for the screw. So even if the screw is slightly mis-adjusted, the horn will still vibrate and sound like an anemic walrus until you get the screw turned just right. It's kind of a fun thing to play with when you have an old tired original.
Are you testing it with it bolted in place? Or if out of the vehicle, with the case grounded to the battery?
I wonder if using the diaphragm as a ground path through the screw has caused any trouble? That might explain why they worked for one or two beeps, but no more.
Don't know, but again would not think so as I believe the diaphragm itself is metal and pretty robust so as to live a long life under the hood.
But maybe there is something to that. It's possible that some of the internal components don't like electrical current passing through them the wrong way.
Hopefully there are some Horn Experts here that can let us know. I know several members have had horns apart. Maybe they can describe what goes on in there.
If it's a defective horn then we will certainly send out another one. Hopefully fully tested before if leaves the building!
