Lots of discussion and debate on our FI fuel systems. There's the low pressure pump feeding an accumulator with the high pressure pump pulling from the accumulator. Then, like what your system sounds like, there's the low pressure pump piped straight into the high pressure pump. Then there's the plain old high pressure pump, which can be mounted either in the tank or external to the tank.
I don't know if anyone has agreed on what's the "best' system for our vehicles, or even a "best" system for a particular vehicles application (rock crawler, mall crawler, dune runner, etc).
Given all the discussion and debate, and given that I have a 23 gallon tank that does not have the provision for an in-tank pump, I decided to stay with the KISS principal. I currently have installed one single E2000 high pressure pump. It's installed pretty near the tank, since the high pressure pumps don't suck all that well. So far, the little bit that I've driven it on the street, it's done it's job. If I run into issues, then I may consider adding other "stuff".
