2000 Explorer Tank Wiring Diagram
ShoeSlinger
I had my new fuel tank made so I could use the fuel pump assembly from my 2000 Explorer donor. Anyone happen to have a wiring diagram for it? I have came up empty on Google searches.
904Bronco
San Martin, CA
I looked for a picture, no luck. There are only two wires you need from the fuel pump assembly, Power and Ground. Easy to match up by looking at the pump assembly. I also recommend harvesting the mating plug from the Bronco donor chassis harness, as if you ever need to replace the pump assembly it is plug and play.
EPB72
Pleasant Hill, CA
S
ShoeSlinger
Unfortunately I have the tank & pump installed already with the pigtail from the donor.
S
ShoeSlinger
EPB72, I will give that new link/diagram a try and hope they use the same pattern. Thanks.
