200ci Boring .4 over
wisconsinbronco
What is a stock 200 bored .40 over in terms of cubic inches and about what would this give me in horsepower figures if it was all stock?
Thanks!
Stock is 3.68 bore x 3.126 stroke = 199.49
Desired 3.72 bore x 3.126 stroke = 203.85
So you are gaining 4 cubic inches or 2% displacment increase.
Power increase will be less then 2% as you are not increasing the breathing capacity of the carb, intake, ports, valves, or any of the exhaust. So you could expect less then a 1% increase in power over a stock engine built exactly the same. You will have bigger differences simply from build variation.
broncnaz
I agree very little HP increase maybe 5 if your lucky. Camshaft choice, good flowing heads are where the power is.
Explorer
Raphine, Virginia
Go to Classicinlines .com and read all the tech articles. If you already have it being bored there are a lot of things from mild to wild you can do to fit your budget.
