2150v Carb spacer question
popsbronco
Edmonton Canada
I was given a spacer about 5/8 of an inc and one gasket.It seems to me i should have two gaskets one on top one on bottom??
How many gaskets to mount the carb and what order do they go in.
Anyone have a scan of the diagram?
ET
Dallas, TX
You need a gasket between intake to spacer and spacer to carb. So two gaskets.
broncnaz
Ditto
I like to use the felpro 1/4" thick gaskets right below the carb it helps prevent heat transfer you could probably use them under the spacer also but you may need longer studs to do it.
