289 timing pointer
gick70
Where is the timing pointer suppose to be as this bronco 289 motor has none?
B RON CO
Statesville, NC
Hi, I'm pretty sure this is a 66 289.
ared77
May be a pointer made into the timing chain cover and someone has installed the wrong water pump over the years. I've seen this before in Mustangs, etc. The water pump lower hose connection (drivers side) covers the pointer. Look close using a flashlight maybe.
gr8scott
Here it is on my 302.
10 O'clock, 11 O'clock, or 2 O'clock are all places Ford has placed timing pointers on small blocks. Sometimes all in the same year on the same model but with different options.
B RON CO
Statesville, NC
Hi, I never really thought about the timing cover. This is a Mustang 4 barrel take out engine I got for nothing. I don't think I got the balancer, water pump, and some other parts. Just a long block core they pulled out. Now I see how the balancer would rub the pointer and some rivet at the bottom. Good luck
gick70
gick70
Here is what I am talking about,looks like the po put some kind of filler in the one hole,I bought a timing pointer but it looks too short,what am I missing?
jckkys
It looks like you have an early '65 or pre '65 289 timing cover that had the pointer cast into the cover and the pointer was cut off. This base is located further away from the fuel pump than the small hole on later 289/302s where the pointer is secured with a small screw. No early Bronco had that timing cover.
