Show Links
I have been battling a 2nd to 3rd gear flare (slip) with my C4. I solved the majority of my problem by blocking the dual ported red stripe modulator's small port, which resulted in a complete elimination of the flare after truck was run a mile of two. I still had the flare for the first mile or so, but shifted great thereafter all day.
I attempted to eliminate the "cold flare" by retorqueing the valve body, given that I did not used torque wrench the first time, readjusting the forward band to 1 /3/4 and switching out the dual ported red stripe modulator to a green stripe modulator. The result was cold flare and flare all the time. I switched back to the red stripe modulator with the small port plugged, given that I am not running an egr, and, although I have no flare when truck is warm, the cold flare still exist.
Any ideas for next steps to eliminate cold flare from 2nd to 3rd?
Thanks for any help.
Rob
Rob
