Bronco Sully
I searched a couple of threads and have an idea as to some of the problem childs for this type of problem. Just wanted to post a pic or two too see if anything on the face seems amiss.
The hoses seem to be hooked up fine. On a fairly high level scan, none seemed to be cracked. I have not checked the vacuum pressure yet but should get to that this afternoon. As you can see, there is a bit of a leak but it is very slow. I cleaned this area off the other day and this is what accumulated after a couple days of driving. No pooling on the floor.
fluid level is perfect and the color seems normal.
The rig is a 1973 pretty much stocker. I have owned it for a couple of weeks. Other than the shifting, it seems very much mechanically sound.
If I replaced the VM, can I expect a bunch of T-mission fluid to come out? Fairly easy to do? If I did this...any other "while your at it" things to do?
I know about as much about transmissions as I do brain surgery...which is nothing!
Thanks in advance!
Thanks in advance!
