3 1/8 backspacing?
roundhouse
Saw some wheels for sale, seller says 3 1/8 backspacing.
from the pics it looks like more than that, but I really cant tell.
Anyone use that?
with 35x12.50's?
NGABronco
Always Learning
N. GA now South Carolina
roundhouse, back spacing gets measured different ways by different folks, I think stock rims are 3&1/2" or 3&3/4". Some ads measure to the outside bead rim and some measure to the outer lip. 76 & 77 's disc set ups can't take much more than 3&1/2" to the outside bead rim. The rims I just bought say a -.38 Off Set, which my tire guy says is 3&1/2 BS. On another label it says 4" BS, it measures 3&1/2 to the outside bead rim and 4" to the outside lip??? The big hitch is with 76 & 77 knuckles.
Hope this helps!!;D;D
Baja71
BS is measured from the mounting surface to the outer lip. The sticker on your wheel is correct, not the tire guy. Roundhouse, get the seller to take a pic of an actual measurement.
NGABronco
Always Learning
I agree with you Baja, I have always flipped the rim upside down, put a straight edge on it and measured!! I think my tire guy's BS was something other than Back Spacing???%)%)%)
Baja71
Yeah, that's how I measure it too. Not sure what he was measuring.
NGABronco
Always Learning
Me thinks he was measuring $$$$!! Cause I was about to tell him to stuff those rims!! He has a small point in that the lip is 1/8" to 1/2" on different wheels and that the lip is usually out of harms way of any obstructions. My argument with him was that -.38 Offset = 4.000 BS. The rims did clear my stock (76') tie rods and he gave me some 1/4" alum spacers, so I have about 1/2" to try to get a better than "inverted Y" steering linkage mounted. Still not sure how I'll go!!!%)%)
Thanks for your input!!;D;D
R
roundhouse
I sent him a link to a site showing how to measure it.
mine is a 74 with the Blazer discs, so I should be ok.
I might get em anyway, the 10 inch slot mags are not easy to find.
NGABronco
Always Learning
Heck round, if it ain't more than 3.25 to the lip or the bead and you don't have those kicked out 76-77 knuckles go for 'em!!!!;D;D;D
(or tell me where they are!!!!)
