3-point Seat Belt Mounting
LSUpete
I've done this on previous builds, but I would like to see how some of you have mounted the belt harness to your roll cage...as well as where you located the retractor housing to the floor.
:cool:
HB73
Mine's in for paint. It'll be a couple of weeks until I get her back. If you still need them I can post then.
xcntrk
NOVA
I mounted all 3 points to my cage both front & rear. Each retractor box is a little bit different, but the ones I used assume the box will bolt vertically and the far end of the belt uses a bracket that would normally secure to the floor. So carry that over to a cage and the box mount uses a through the tube bung while the far end bracket mounts to my footplate. Then the shoulder 3pt mount uses another through the tube bung. And lastly the receiver mounts to floor bars using yet another through the tube bung. So they actually mount in 4 places, 3 using through the tube bungs, and one mounting to the foot plate.
Here's some grainy pics..
pipermike
Xcntrk I still think your cage is one of the best I've seen, great job!
jarhed1984
Homosassa, Fl
Not sure if this helps. Mounted the top in the 45 degree position of the bend in the roll bar. If not the belts would be slack. Seems to be fine. This is a wild horses 3 point.
graniteguy
Kempner, TX
mine is like jarhed but I overdilled the hole, slid in a piece of 1/2
tube, welded it, and grinded flush. Prevents any collapse of the roll cage tubing.
I did the same thing at the back to the th roll cage to the bed side. My beds were bent outward. This sucked it back in and made it very stiff.
