3 spd column
Harley
Leon County
After installing my rebuilt 3 spd I was mocking up my linkage with the Trans in N, I was confirming the column was in N with the linkage connected at the column but disconnected from the tran. The neutral area within the column seemed to move, when I first found N it was low towards 1st/3rd but if I held the shifter in the center I could move the N cross section up and down. Is this normal?
thunderball
Raleigh, NC
That is not normal. You should do the ol' drill bit trick. It's detailed in a bunch of places on here, so do a quick search.
It's basically loosening your lever connections and inserting the bit into alignment holes on the shift levers on the column (under the hood). Once you do that, retighten all connections and remove the alignment bit.
