Dantheman365
- Joined
- Sep 30, 2012
- Messages
- 19
Dropped the transmission and tranfer case out of my 73 to replace the gaskets and while I had them out I replaced the clutch etc with a new clutch kit (pressure plate,clutch,throwout bearing, pilot bearing) and had the fly wheel turned. Threw it all back together and now the transmission will not shift.Additionally, it seems the clutch will not disengage (im guessing the two are related). The clutch fork has very limited play when I attempt to manipulate it. Im gussing im gonna have to drop everything again, but i'm not sure exactly what the issue is.
I didnt even open the transmission up, just cleaned it up and painted it. I ensured it remained in 1st gear from thr moment I pulled it, and I'm pretty sure thats what position its stuck in.
I tried starting without the drive shafts in and it almost turned over, but i'm afraid i'm gonna fry the starter.
Trasfer case seems to work fine, as I am able to move the yokes when dissengaged.
Any Ideas?
I left it in 1st when I pulled it and was especially careful not to knock it out of gear.
Any Ideas?
