There is actually an adjustment procedure. I'll see if I can find it in the book, but until then, basically you do the following:
1. Disconnect the shift rods at the shift levers on the side of the transmission.
2. Make sure that both levers are clicked fully into their Neutral positions.
3. Back up at the shift arms on the column, line them up and put a drill bit of the appropriate size through the small aligning hole just below where the shift rods connect.
4. This is the time to feel around to make sure there is no excessive slop in any component. Whether a rod, a bushing, the column itself (the shift tube can wear out and actually break) or the transmission itself by how the levers feel.
5. Now go back down and try to line the shift rod adjustable tips up to the holes in the levers. If they pop right in, you're set. If not, then twist the adjusters until the tips line up in the holes.
I seem to remember preferring to put them at a certain tension one way or the other, but it's literally been 30 years since I had to adjust one, so it's hard to say which way I biased it from memory.
Just put them in where they feel good and see what you get. From there you can easily add or remove some adjustment.
Oh, and don't forget to "pull the pin" (drill bit) before you try shifting!
