3 speed hurst not shifting
Tmckinney
Pearland, Houston
When the truck is sitting not running, the truck slides right into any of the four gears.
I have played with the idle adjustment screws on the carb and have experience some improvement in ease of shifting.
when it is running I have to force the transmission into 1st and reverse. 2nd and 3rd are no problem once the bronco is up and moving. When going into reverse it definitely grinds and has to be jammed into gear.
I replaced the clutch not too long ago and thought that i had the clutch adjusted properly.
I start my carb adjustment at 2 full turns out and lean and rich the mixture from there.
Forgive me for my ignorance but i've taught myself everything I know about mechanics.
Does this sound like a clutch adjustment issue, carb adjustment, or both, or even something else.
Thanks,
Tyler
broncodriver99
Glen Allen, VA
Have you checked the fluid level in the transmission and what type are you using? Reverse is not synchronized so it won't slip right in. The forward gears should shift pretty smoothly though. I am betting low or too heavy of a trans fluid.
The only other thing I can think of is that you aren't quite completely disengaging the clutch.
70_Steve
Old Guy
I agree. And this could be one of two things. Either you're not pressing the clutch pedal all the way down, or the clutch is adjusted improperly.
A properly adjusted clutch should have 1" to 1 1/2" free-play at the top of the pedal. That is, even with your hand, you should be able to push the clutch pedal down about an inch or so pretty easily, then start to feel an increase in resistance. With the pedal adjusted like that, the pressure plate should move sufficiently to disengage the clutch.
The only other thing I can think of is that your clutch disk may be warped, so even with the pressure plate not clamping the clutch disk, the clutch disk is still being rubbed between the flywheel and pressure plate.
There's a couple ways the clutch disk can become warped. Most of them have to do with improper R&R of the transmission.
baddad457
The blocker rings (syncronizers) are worn on 1st. Time to rebuild it. Good thing is the rebuild kits are cheap and these transmissions are easy to rebuild. All you need is a good pair of snap ring pliers and a fishing magnet (to fish the shifter detentsn out of their holes) You can get a rebuild kit from David Kee Toploaders in San Antone. www.4speedtoploaders.com for $150
T
Tmckinney
Pearland, Houston
I checked the play in the clutch and found about 3-4 inches of play in the pedal. I'm going to readjust the clutch pin and have a test ride. will report back soon. If I drop this 3 speed again it aint goin back in. so hopefully its just the clutch adjustment
baddad457
Might also try readjusting the shifter rods too. 1st and reverse are together on a 3 speed (I was thinking you had a 4 speed) so the linkage rod may need further adjustment.
T
Tmckinney
Pearland, Houston
Ok. adjusted clutch pedal to proper height and shifting problem solved. Now I'm working on tuning out my bucking issues...
I think this has more to do with my carb. Every time i touch throttle there is loss in power and a "shhhhh" sound. cant even get the bronco back in the garage.
