As the title says I have a 3 speed with the shifter on the column and I installed a 1 inch body lift. My shift rods are now too short. What do yall do to fix this other than moving the shifter to the floor? Is there an aftermarket fix?
I think Wild Horses sells the extended rods?
My body lift came with one inch extension pieces that I welded in.
Thanks,
I'll see if I can find them on their site. I looked yesterday but all I found was the extended clutch rod.
Thanks, I'll see if I can find them on their site. I looked yesterday but all I found was the extended clutch rod.
Well that's off the table then. Bummer almost, because at least then it would have been a known issue.
But this is at least consistent with what most of us have experienced, with being able to use the stock rods without modification.
No chance they're on the wrong levers at the trans? I don't think this is possible, since if you swapped them they'd likely interfere with each other long before reaching the trans. They're tricky little bent buggers.
You asked about getting things backwards though. Have you found any images of how the arms are on the column? I don't have mine handy or I'd snap a pic for you. Maybe the shop manual shows which one goes where on the adjusting page.
Hopefully someone else has a shot of theirs.
Have you looked into Vipers suggestion of lowering the column slightly at the firewall end? You're not really having trouble with length, as you said. But maybe the angle is messing things up.
