300 big six is in
AWS
ST LOUIS
Well Matt pulled his little 170 out of his 66 and sold it to a Falcon guy yesterday and we dropped in the 300. So far its been easy since the 170 and the 300 are the same length from the mount back. Found some mid 70's f150 mounts and made some little brackets for the frame horns. Today we'll do the radiator. Here's some pics
Buldozer
Bronco Virtuoso
God's Country
Nice project! I can't recall how many times people have asked me if a 300/6 will fit in an EB. They want the bigger torque of the 300.
JC
Conway, Arkansas
YES, AWS please keep up posted on this. I was under the impression that the motor mounts had to be moved. Looks like you had to take some out of the crossmember for clearance. What other issues do you forsee, clutch linkage, radiator mounting, etc.
I miss my old truck with a 300 and would love to have one in the Bronco. This could be a future project for me if it doesn't get into too much fab work.
AWS
AWS
ST LOUIS
If you start with a six it fits in the same frame horns.
Took out too much at first, we'll just fit the piece we removed back in just a little lower.
Clutch linkage we'll use 302 stuff don't see any reason it won't work, if it doesn't we have the F-series bellhousing that uses the external slave cylinder. Radiator will be moved forward about an inch. Throttle linkage is a snap since the little 170 uses a cable already.
When we're finished I'll make up a few extra sets of frame horn mounts.
Steve
Explorer
Raphine, Virginia
Inspiration Only! crozetcrew sent me this pic. Please don't ask questions, I have no answers. How much weight diff to compensate for?
AWS
AWS
ST LOUIS
Thanks Ben. Words can't describe how good it is to see him excited about his bronco again since getting wrapped up in the highway cables. Right now he's trying to finish for the Rocky Mountain Rendevous. I think I'll miss the sound of that little 170 pushing 4.88 and 36" swampers. He'll have to learn how to drive it all over again. LOL
Steve
bigmuddy
Marthasville Missouri
They are hopefully in Colorado for the Rocky mountain run and won't be back till next week from what I understand. I hope they got the big 300 and running and I will be anxious to see how it worked out in the thin air of colorado.
Ben
bigmuddy
Steve,
Its good to see anyone enjoying working on an ole bronco. I have been avoiding mine for too long again. Wouldn't have been such a long down time with Matt if you guys knew what you were doing when installing that complicated steering system! LOL!
Ben
Pa PITT
Stephenville TEXAS
Tell us again where your at on this swap ...I have a 300 np435 in a 1980 I'd love to have one in a EB.. Need to hear more ..How are you fitting in the rad..
JC
Conway, Arkansas
Ben
Thanks Ben. BTW, I enjoyed the visit yesterday. You've got a really nice Bronco.
lonesouth
finish your 4bt, detail everything with pics, measurements, part numbers and directions...then we'll let you start on a 300 swap.
66broncoluvr
St. louis, MO
i have already done it!
Thanks Steve...
Sorry guys, haven't been on here in a while... new baby so bronco goes on back burner.
I have actually done the transplant completely. 300 into a 170's space. As I told Matt there are issues with the mounts. You have to cut them out a little higher. The cross member in front needs to be lowered, or just cut the top section of the c channel out. The clutch linkage is tricky... you have to remount the linkage from a f series truck using the bottom original hole as the top and drilling a new one for the bottom. I wish i had gone the route of the slave cylinder, would have saved a lot of headache and fab work. The radiator needs to go forward about an inch... granted we are talking about mounting in a 170 engine bay not 302. The three speed or c4 will go right back in place and np and others require their usual tranny mount adjustments. To run a carb or efi I would strongly insist on a 2" or better body lift and a high rise hood. She is a tight squeeze and exhaust is a lot of fun to mess with... typical 300 headers will not fit period! the shortys from clifford or just stock manifold work just fine. Like I said, been a little preoccupied with things. Power steering will fit also!
Next time Steve, just mention this to me and I'd me happy to post about it. After all u were the one asking me the questions for one!
I will post pics as soon as the temp goes up just a little... currently 9 deg. and no garage! Sorry make that 8 deg.
JC
Conway, Arkansas
Thanks for posting 66broncoluvr!
What radiator did you use? Also, what motor mounts? Earlier in this thread something was mentioned about fabbing some frame horn mounts? Thanks!
