ptwist
- Jun 27, 2018
- 155
So I basically blowed up my the engine. I was told by the PO that the engine was bad and hadn't run in 7-8 years so im well ahead with having driven it 600+miles.
A couple weeks ago it developed a intake gasket leak so when I was replacing the the gasket I noticed it had a few bad lifters and push rods. A new cam, lifters, and push rods later it starts and runs great. Break in the cam and take her for a drive. A couple miles from the shop oil pressure goes to 0. Drove it home and pulled a valve cover to find a little debris setting on the head and one of the lifters had popped off the valve. Come to find out the intake valve seals had exploded and it lost oil pressure because of that. A lifter and cam died driving it home.
What im needing help with is where to go from here. The engine is still in the truck but im not sure if I need to pull the engine and check the crank bearings complete rebuild. Should I just clean the oil pump and passages put a new cam and valve seals on it? Its the least desirable 302 made and it seems to have a big lip on the cylinder walls so seems to have lots of ware.
Its going to get a coyote swap in the next year or so but I would like to keep driving it around till I track down an engine.
