I am selling a ford 302 from my 74 bronco. I replaced this engine with an blue print EFI engine. It is a strong motor. Was rebuilt by PO recently.
Has the following performance parts.
1. Comes with MSD distributor and a new Msd pro billet distributor. http://m.summitracing.com/parts/msd-8579
2. Edelbrock performer intake manifold.
3. Holley card 600cfm
4. Ford motor sports valve covers aluminum finned.
5. Comp cams roller rockers
6. Comp cams cam with hydraulic lifters.
7. New oil pan.
8. Braided lokar dipstick.
9. Ceramic headers. From WIld horses. Needs flanges.
10. Msd coil
11. msd ignition
12. New air filter.
13. Edelbrock air cleaner.
14. New oil pump.
15. New fuel pump
16. Engine stand. Is missing two of the four mounting arms. Summit messed up my order and shipped the engine stand with two of the four arms. It holds the engine. But cannot rotate it.
Does not include the following
Thermostat housing
Thermostat
Sensors, water or oil pressure.
Water pump
PCV valve
I also have some misc parts that you may also like.
Helper fan 10 inches
Fuel accumulator
Electric water pump
Motor mounts
Muffler
1,200 or best offer.
Hit me up. This is a great motor. Is just as strong as my new blue print 347.
Aaron (Vienna VA)
if I don't get back to your pm just text me at 703-868-6028
7. New oil pan.
10. Msd coil
11. msd ignition
12. New air filter.
14. New oil pump.
15. New fuel pump
Thermostat housing
Thermostat
Water pump
PCV valve
Fuel accumulator
Electric water pump
Motor mounts
Muffler
Aaron (Vienna VA)
