IMO... Unless you are going to use nitrous or supercharge it, hyperuectic pistons should be fine. Forged pistons have different expansion properties and need more clearence between the piston and firewall, and can be noisy, beside very expensive. I have used the Summit kits before and they seem to be pretty good quality. The bearings and rings are good quality, and the pistons were very close when I had them balanced. I'm sure you could go cheaper, but it is a complete package. Add a good quality timing chain and water pump and you should be on your way. I believe that a good machine shop is more important than the build kit, and sometimes there build kits are cheaper also... The guy I use fits the pistons to the cylinder bores to ensure they are machined right, and I know alot of them don't do that... Good luck.
