302 overheating/temperature sensor
inthmtns
Martinsdale, MT
Just an FYI in case some other folks run into this...
Earlier in the summer we lost a head gasket in our 5.0 powered-Class 7 Ranger (baja racing). The engine temps hit 245 midrace so the driver shut it down, added what extra water he had and limped it back to the pits for our very first DNF.
Back at the shop for repair and prep for the next race we decided on upgrading to new Edlebrock aluminum heads.
As this is a front engine/rear radiator truck, it take quite a lot of bleeding/heatcycling to get all the air bubbles out of the cooling system. After 5 hours of this, we finally got the air out and the engine settled at 205 degrees (180 thermostat). Hmm, not good.
On the pre-run the day before the race the engine temp shot up to a steady 245 degrees and stayed there. No amount of bleeding made any difference.
We were about to pull our entry when a friend who races with us (Eddie Smith of Bigfoot Monster Truck fame) grabbed a hand held heat gun and took a reading at the sending unit.
190 degrees!!! Heads 195, manifold 193, radiator 135!!!
Lesson learned? Dont always trust your gauges!
When you over temp the sending unit (even on high end liquid filled gauges) it is likely that the heat has damaged it and will give you a false reading!
We stayed in the race and went on to an easy 1st Place finish...
