I have been running a melling high volume pump in my 289 for the last 13 years with no problems, and it is in my 71 bronco with the stock oil pan. it does not put out excessive pressure. I have run them in several 289 and 302engines, and never had pan clearance issues, but if you are going to run a high volume pump replace the oil pump drive with the ford motorsport oil pump drive shaft. I twisted a stock shaft in my drag car (was the first motor I ever built) found it when I went to do a cam swap and it had about 1 1/2 twists in it, luckily it had not snapped, now I use the upgraded shaft in all my engines.
