302 stored filled with oil.
1971lubr
Cape Coral, FL
About 12 years ago my 302 was filled with oil since we knew it would be a long time until it ran again. The valves were opened and it got filled in an attempt to keep it as fresh as possible during storage.
In preparation to put it back in the Bronco in a few weeks, does anyone have any recommendations on getting the oil out? I'm assuming it's going to be fairly messy, so it makes sense (to me) to do it before it's in the engine bay.
Suggestions?
Wyflyer
Is the crankcase/valve cover/valve lifter area also flooded? Or just the cylinders?
I think a low tech solution is the way to go. Either hang on an engine stand, pull the spark plugs, put down some plastic, wrap block in plastic and turn over the engine till it all runs out the spark plug holes. Even better if you can turn it with the spark plugs down. Wash it down with solvent.
Or... use a wet shop vac and use a small suction hose in each cylinder to evacuate each cylinder.
Don't wash oil out with solvent. Horrible idea. All that protection that it may have been doing for the past 12 years will be wasted by removing that layer of oil then trying to start it.
There is a pretty good chance that a lot of the oil has leaked past the ring gaps in the past 12 years, but I expect there to still be enough to cause issues unless you take care of it first. Only one way to do it, pull the spark plugs and turn the engine over. I can't think of a clean way to get it out. It is going to come out of all the plug holes and some out the exhaust ports as well.
And if you really filled the engine, as in gallons of oil to the top of the valve covers, just drain it all out before you start anything else.
Wyflyer
I didn't say to wash the cylinders with solvent. I meant, wash the engine down with solvent. Thanks for tastefully clarifying that for me.
OK, with that clarified, washing down the outside of the engine with solvent to clean up the mess that will run out of the spark plugs is good. Might hurt the paint (depends on paint and solvent) but that is easy enough to fix.
00gyrhed
since the engine is out its not going to be that big a deal. But since you asked I assume you wanted a detailed explanation.
Even if you filled completely to the top of the top of the valve covers and carburetor almost everything except what in the cylinders is going to drain out when you drain the oil pan. You would have had to taken off valve covers and loosened up all the exhaust valves so they were all closed for there to be a lot of oil backed up about the top of the lowest open exhaust valve. Oil poured down the carb would have just run out the lowest open exhaust valve, so after twelve years everything above the lowest open exhaust valve will be dry.
Drain the oil from the pan. Everything but what is trapped in the cylinders will drain out.
find some hoses that fit snug into the spark pull threads and (An engine stand makes this easier but it is not required). With the engine upright just rotate the cranks shaft by hand at least two full revolutions this will get the majority of oil out of the cylinders if anything is left after 12 years. Then just roll the engine over to one side to where everything in that sides bank of cylinders can drain out through the spark plug hole. You will have to roll the engine two revolutions again to make sure the exhaust valves all open. when you get a flow of oil just stop and let it drain before going to the next one. repeat until it stops dripping then do the other side.
put new properly gapped spark plugs back in it and let it sit until you actually get ready to fire it off.
when you are ready to fire it off drain the oil pan one last time. Some more of the old oil will have probably found its way to your pan. Put in 4 quarts of new oil and if you want to play it really safe pull the distributor and run the oil pump with a drill until you get oil pressure up for a few seconds, but that's probably a waste of time if in fact it was left completely full of oil.
Right before you fire it off. DO NOT PUT GAS IN THE CARB OR HOOK UP THE IGNITION. Just crank it some, the compression cycles will drive out a good bit of the oil that might remain in the cylinders. Then hook up everything and start the engine.
Now that I told you the safe and clean way I will tell you how we started an old Chevy inline 216 head that my buddies father had stored 50 years with all the exhaust vales closed and intakes open and filled to the top of the carb with oil and left sitting in the chassis. We drained the oil from the pan, adjusted the valves, pulled the spark plugs, cranked the engine, put in new spark plugs, cranked the engine, then put gas and ignition to it and it fired right up and ran just as good as when it was stored, at least we assume that. We were 2 when it was stored, and his father has been dead a while. Believe it or not that really wasn't that messy. The oil in the cylinders just went out the exhaust and either got burned up or just dripped out the end. There was some smoke though :)
Oh yea I meant to say the after 50 years of sitting there was a oil spot where it had been leaking out through the closed exhaust vales at the end of the tailpipe. Also just in case someone cares this was actually a hot rodded GMC 296? inline 6 in a 34 Chevy coupe. My old head typed 216 because that is the older chevy version of this engine.
1971lubr
1971lubr
Cape Coral, FL
00gyrhed, that's exactly the information I needed. Thanks a ton!
We did fill to the top of the carb. But, somewhere along the line the dipstick got moved and the last few years it's been slowly leaking. The old tire it was resting on was full of oil when we moved it last week.
