OlliesBronco24
- Sep 30, 2024
- 10
Good evening everyone. I have dug and dug and have just decided to throw it out to the experts. I have the original 302 motor that had a lot of slop in the timing chain and leaks up front. I decided to change out the front assembly and do the timing chain while it was all out. I got a bit ahead of my self and ordered the wrong chain. The motor originally had a 2 piece Eccemtric timing chain as I still plan on running the manual fuel pump. I got a 1 piece chain. I’m going to pull the wrong one and put the right one on, but that’s where my questions start.
What 2 piece eccemtric timing chain will work with the factory timing chain cover and belt set up?
The harmonic balancer is cooked. I was looking at the WH. Which balancer will work with the timing chain question above? I’ve read about chains rubbing on the timing cover from the wider chains and then pushing the balancer out a bit more.
Everything else is stock and the engine ran well and didn’t smoke before the tear down.
Thanks!
Thanks!
