303 to dana 20 install problem
Curbanator
Hello,
I am having a heck of a time bolting up my Dana 20 to my three speed. With the adapter installed onto the transfer case, it seems to be binding on the transmissions rear bearing. I must be missing a step here.
Thanks for your help,
Curtis
Viperwolf1
electron whisperer
Has the rear shaft and bearing come out from the case? If so you need to open the trans back up and fix the input roller bearings which have fallen out of place.
There is a procedure to lock the trans in a certain gear, I think 3rd, that will prevent that shaft from pulling out.
