31x10.5x15 BF Goodrich tires on factory rims
vtboy51
I know this has been discussed to death, but I wanted to get one round of answers before I order my new tires. I have a 2.5" suspension lift, uncut fenders, and NO body lift. Currently have 30x9.5x15 tires, but they look small and wanted to go up a size.
Two questions, will putting a 10.5" wide tire on a factory rim give me grief and will it fit inside my rear fender without rolling the lip? No off roading, it is on dirt roads and pavement.
serial car restorer
Yes, I'll restore almost anything...
Western Oregon
If you are talking about stock steelies, they are either 5.5" or 6" wide, depending on what year they came from originally. A 31x10.50R15 is approved to fit 7"-9" wide wheels. You can probably find a shop that will mount them on the narrower wheels, but it is not really right, and pinching them on a narrow wheel like that will affect wear and drivability.
But not to any great extent. Especially if you're not driving your vehicle many miles a year.
It's correct, that most large chain stores are not going to mount them on your stock rims for just the reason cited. The tire manufacturer's recommendations.
Not surprising though, since these days a 7" wide factory wheel is more the norm than it was back in our vehicle's day.
With a Bronco, there have been many, many people running that size tire on the stock wheels. Not to say they were perfect, or that they didn't wear a little more in the middle (especially if you didn't modify your air pressures), but it should work.
But will it fit without rubbing? I can only say with 90% certainty that they will. Over the last 50 years or so, we've certainly seen some that rubbed. But I've known far too many people with 31x10.50's on their uncut Broncos with no rubbing to say it's not going to work.
If in doubt, mount just one up and install it on the rear right there at the shop. Test fit it to see if your Bronco is going to be one of the normal (does fit) ones, or one of the oddities (does not fit) ones.
Oh, and while you're in the decision phase still, I would measure your axle-to-frame clearance to make sure that you're not sagged down a bit already. The loss of an inch or so in original ride-height might just make the difference.
You're looking for 7" in the front, and 6" in the back, between the frame and axle tube. Any less than that is your sagged height less than stock. Approximately....
If it's sagged a bit, and you carry passengers, I could see a 10.50 occasionally rubbing on bumps and such. Especially if you carry adult passengers. Kids don't seem to cause much drama.
Well, in the ride-height department that is!
vtboy51
vtboy51
Thanks for the responses. I just did some measuring, I've got about 9" up front and 8" in the rear, I've got the 2.5" wild horses lift (2 years old).
Blitzen72
You have my exact setup... 2.5" WH suspension lift, uncut original body, and 31" x 10.5 BFG ko2's on 8.5×15 rims. Even flexing, the only time I rub is during a really tight turn the inside of the front tire rubs the radius arms. You can see my stance in my pictures
