i can do that but i think my speedo gear is way off... lolOk back to not so serious, but Brian is right, only thing better than 600hp is 700hp lol
You mean this isn’t normal cruising speed for broncos? Let alone ones that wheel with Bailie for 4 days and drive home?![]()
Shortly after I got my 408 running and broken in I had a male teenager moment and stuffed the right pedal with a GPS app running on my phone. 120 even when I lost my nerve, and before I lost my Bronco, or worse. Wish I had a video to prove it. Not that it matters, because I'm never ever doing that again. That said, it was still tracking straight. We have a lot of arrow-straight empty rural roads around here so finding the venue wasn't an issue. Did I mention I'm never going to do that again?All my fault TS...took decades.
I know who "he" is!! lol
Probably eating herring on pumpernickel bread as I type!![]()
5.0 (302) based engines have a deck height of appr. 8.2"
5.8 (351W) based engines have a deck height of appr. 9.5"
The 351W fits under a stock hood. Your intake manifold is usually the deciding factor for generating clearance issues as it's harder and more expensive to swap out.
Look up Edelbrock and reference the height differences between the Performer and SuperVic intake manifolds. They both fit on 5.0 and 5.8 blocks but the height can make clearances to the hood super tight.
A 351 based block with an Edelbrock Performer and aftermarket fuel injection with a drop base air filter with an excellent flowing 2" tall classic air filter fits perfect. I have done several of these so this is a guarantee - lol If you end up with a small body lift to help with trans tunnel clearance and the other dozen things that a small body lift helps with then you are even farther ahead and highly recommended as it gives you call kinds of small clearance benefits.
FWIW, I wouldn't trade the torque and reliability of my 351W for a 302. You can make a 331/347 produce similar numbers, but the 351W is going to do it for less money IMO. If I were to swap my 351W for anything, it would be a stroked 351W like a 393, 408, 418, 427, etc., with the 408 being a nice compromise between RPM and torque with the square bore/stroke configuration.
Given the choice, I would go with a 351. The 5.0 engine, look inside and my best discription is Dainty, delicate perhaps? 400HP is typically known as the point the block starts splitting in two as well. The 351 has the beef to be a truck engine. The Bronco is no fox body mustang, don't try to treat it as one. The basics of a 351 are just a much more solid foundation.
THANK YOU. you justed saved me a few thousand!No. Pull the 5.0 out of the 92 and run it as-is, stone stock in the Bronco.
Only a fool would stroke an 8.2 deck small block Ford in a Bronco. There is plenty of room for the 351W. So why would you ever make the spend? If all things were equal, then a 331, or a 347 makes sense. But all things are not equal. You can get a roller 351W from a 96 F150 for $750. You HAVE a roller 302 from a 92 Mustang 5.0. It's not even a question.
And you don't want to put 400 Horsepower in front of a NV3550. If I did that, I would break it.
And you don't want 400 HP in a Bronco. You won't use it, you can't get it to the ground, you don't need it, and if you do ever get it hooked up...you can't steer it, or stop it.
Do youself a favor, and stop looking at magazines, and speed shops, and stop bench racing. Take all the money that you were going to spend on your stroker, and buy induction, exhaust, fuel management, fuel supply, brakes, and suspension. Build a solid, reliable, bulletproof and streetable 240 Horsepower. Then drive it like you stole it.
Let me assure you that it is vastly more fun to drive a slow car fast...than to drive a fast car slow.
That's my $.02.
As for finding a local engine builder, those are getting hard to do these days. Anywhere in the country. Can't help with your location.
Pretty accurate:
"So, long intro to a simple answer:
1. More money than brains: Coyote 5.0
2. More time than money: 1996 Ford 351W.
3. I break shit, and like to go fast, and when someone is stuck, they call me: Blueprint 408W.
4. I ain't rich, and I need a Bronco that runs now: Mustang 5.0.
5. I need cheap reliable horsepower, I have no friends, and I don't want any: LS swap."
The engine in my '72 EB MX racer dynoed at 480 or thereabouts, at 7300 RPM, and I used every last drop of that..often.Ah, James. You are right. Who would want 400 HP in a Bronco? 450 is better![]()
Lots of wisdom in this statement. When I was young enough to think I was right, I hadn't yet realized I wasn't old enough to realize I was wrong. Bronco frames/drivetrain/etc won't do well with massive power. My little rollerblock mildly build 302 (with Ford SEFI) put out 285 ft/pds torque at 2750 rpm. MORE than enough unless your doing serious off-roading/large tires/crawling etc.No. Pull the 5.0 out of the 92 and run it as-is, stone stock in the Bronco.
That's my $.02.
I guess I'm in trouble because I'm dropping in a new GEN3 Coyote mated to a 10 speed auto. I'm pretty sure the it's 460 HP bone stock,No. Pull the 5.0 out of the 92 and run it as-is, stone stock in the Bronco.
That's my $.02.
I guess I'm in trouble because I'm dropping in a new GEN3 Coyote mated to a 10 speed auto. I'm pretty sure the it's 460 HP bone stock,![]()
I rode the short bus, so help me with your comment to me, thanks...... you could have saved some typing if you had just said: "I'm a #1"
I am with you Todd.I'm a #4.
Todd Z.
I like the short bus! Most of my friends are on that bus. So you are in good company. But the decoder for the categories is in post #13 of this thread.I rode the short bus, so help me with your comment to me, thanks...
Thank you and I really appreciate it. I was back and forth on what motor to drop back in my '77. Left a factory with a 302 but someone replaced it with a 351W. I said heck with it and went all in with the chips.I like the short bus! Most of my friends are on that bus. So you are in good company. But the decoder for the categories is in post #13 of this thread.
Coyote owners already have their own category.
The categories became necessary after I got flamed because of my comment in post #3. That's where I said:
"No one needs 400 HP. You won't use it, you can't get it to the ground, you don't need it, and if you do ever get it hooked up...you can't steer it, or stop it."
Of course, as soon as I posted it, every yokel with a stroker had to come out and proclaim their superiority. No point in arguing with people that are smarter than me.
But the fact remains. 460HP will push a 3800lb object to a speed of 114MPH in 11.77 seconds in 1/4 mile. NOBODY is driving their Bronco at 114 MPH. Now as soon as I remind people that they are not actually Producing 460 horsepower, (but they do produce a lot of noise and heat...) somebody will produce a video of @nvrstuk doing superman things with his Bronco, and prove me wrong.
