351 and Angled Brake Bracket??
u10072
Another 351 question-- will an angled brake bracket work in a 351--with a 1" bodylift, extreme mounts and I am going to be running tall aluminum valve covers as well.
I have zero problem modifiying something to work if its close. Thats a pic of what I am working with --I didn't think that lower bolt was used on the angled brackets???
thanks,
Matt
gabe1974
I had to cut the bottom of the bracket closest to the valve cover to make it fit.
mattt
Mine fits with no modification and stock engine mounts. I never bolted up the bracket when the HD mounts were in, but I don't see it being a problem. The only place the valve cover got close to the firewall with either set of motor mounts on my 69 was near where the throttle linkage & the early style rectangular wiring connectors came thru the firewall. If you look at older threads of mine from about 1.5 years ago there is one with pics during my install and what I ended up doing to make everything fit with minimal modification.
I noticed in your other thread, it appears you re-made the firewall on the angled portion in the center, drivers side. Was yours hitting something right there?
vinson
south bend
I;m running 1 inch body lift, stock motor mounts with ford racing valve covers an it all fits nice.
markperry
I don't have a body lift, so I did have to modify the angle bracket........
chuck
Ingram, Texas
The tall extreme motor mounts are the likely problem but there are other things that can be causing you problem. A few things that come to mind is, the body is too far forward, the motor mounts are too tall, the frame mounts are too far back or the body mounts are lower than stock. My 70 has a 351, Q-jet, stock hood and a ZF and no body lift. My EB is not special but it does seem to be diff. than a lot of other EB. Others seem to have the same results while still others can't get anything to fit. I think the EB's were made with very loose tolerances and subtle changes over the years. To that we add aftermarket stuff like motor mounts, EFI, air clearners, P/S, P/B, A/C, 351 and surp. belts. It's a wonder anything fits.
hartbronco
Powell River B.C Can
Chuck thats what I was thinking too. The more we change things from stock the harder it will be to get all the other Mods to fit .... and so on. like You said they all seem a little different from each other .
garberz
Bronco Influencer
Conejo Valley, Ca.
..........My EB is not special but it does seem to be diff. than a lot of other EB. Others seem to have the same results while still others can't get anything to fit. I think the EB's were made with very loose tolerances and subtle changes over the years. To that we add aftermarket stuff like motor mounts, EFI, air clearners, P/S, P/B, A/C, 351 and surp. belts. It's a wonder anything fits.
Good point Chuck, unfortunately for vendors like yourself, more people don't understand this.
chuck
Ingram, Texas
Also the parts change, We are having trouble right now with a simple t-stat housing. The new one we have used for years and it looks very much like the factory one but the after market one just changed, now it actually hits the heater hose tube. Now we are working on having one made.
bad 68
Northest Washington
I did have to cut a notch in the lower part of the PB bracket to clear the Tall Ford valve cover on my 351W. I am running SVO full roller rocker arms so the valve covers arn't just for looks. I have no body lift. I can't say for sure what motor towers were welded to the frame as the PO did the I6 to V-8 conversion.
