351c to c4
73bronc92
Hey I am just double checking. I have a 351C bolted to a 3speed tranny on the floor. Im running 35's and 3.50 gearing its a dog like that. I want to swap to a c-4 and 4.11's. Will a C-4 bolt up or what will I need. Thanks in advance
Viperwolf1
electron whisperer
You need a short, 28 spline output shaft (4x4) C4 with a 164 tooth bellhousing. That's the hardest part to find, the other small parts are easy.
Madgyver
Bronco Madman
Just find a C-4 that was in an early bronco..
If you need to piece one together then you may as well build an OD auto, AOD, 4r70w, 700R4
