351W Cam choice
hawkgt
Leesburg, VA
While the body is off getting painted I am doing final prep on my motor. It is a recently rebuilt 351W and will be running a Quadrajet, Edelbrock Performer intake, stock heads, BC headers and single exhaust. The truck will be used for weekend driving and wheeling on 35/12.50x17s and 4.56/4.88 gears. I like the idea of putting GT40 or aftermarket heads on one day but staying stock for now to get it back on the road.
My question is will I regret not putting in a cam while I have the motor out? If I put in a mild RV cam do i need to replace the springs, keepers, and retainers (i.e. K-kit)? The more I read on recommendations the more frustrated I get with the decision. I keep looking at Comp Cams XE256H and XE262H/X4262H. Any final suggestions before I button it up with my explorer serp set-up? TIA!
blubuckaroo
Grease Monkey
Ridgefield WA
Any time you change your cam, you should weigh the valve spring rate to make sure they're compatible with your new cam. Usually a little shimming is all that's needed to bring the pressure into compliance. It's really a small investment compared to the things that can happen by not doing it.
broncnaz
I say put the cam in now a good cam makes more differance than heads, intake or headers. Plus a cam swap is harder to do once the engine is installed. Later on if you want to install heads you will already have a decent cam to support the heads. Id agree on the bigger cam ie 262/268 and maybe even up to 270 depending on what the rest of your setup and driving needs. A 351 doesnt need the super lowend cam like a 256 as it already has a good lowend due to the stroke.
As was said springs need to be checked for proper hieghts and pressures when cams are changed. Most likely it would be ok with stock springs but you want everything in spec. The K kits just match everything up but you dont always need all the retainers, keepers or timing chain set. Of course the smaller cams are a little better suited for stock valve trains.
rguest3
Agreed the XE256H is too low for the already torquey 351w.
The XE262H or XE268H will do great. I advise getting the K-Kit with the Cam and will include ALL matching Valve Train as well. No guess work and no hoping all works together.
chuzie
I am in the same boat but drive long distances to events. How does a cam like this affect gas mileage?
Rickb1b
Can't speak about the cam in a 302 but I had a crane 262 cam in a 327 once. Gas mileage actually went up a little bit. Probably because of all the upgrades not just the cam, but I don't think the cam alone would cause it to go down. What caused it to go down was the car had such great response at around 3000 RPM I couldn't keep my foot out of it.
hawkgt
hawkgt
Leesburg, VA
I appreciate all the feedback. Comp Cams web site suggests a 2200 stall torque converter be used with the 268, so ordered the 262. This should be a good step forward with the other bolt-on additions to the engine. I went ahead a spent the extra money and got the k-kit so I know everything will match and not cause problems. The big brown truck is scheduled to deliver it today!
Since I ordered the cam I have been reading up on which oil I need to use to ensure I don't wipe a lobe. Several weeks ago I watched the Fast and Loud episode where they used plain O'Reileys oil and destroyed the cam during break-in. There seems to be lots of info out there on zddp ratios and which oils provide sufficient protection for flat tappet cam break-in. The two oils my local auto part store carry are Valvoline VR1 20w-30 (gray bottle) and Mobil 1 20W-50 which both have high levels of zddp (zinc >1200ppm) and sufficiently viscous to maintain a thin film. Has anyone used these oils to break-in a new cam or are you going with a plain good quality oil and letting the moly assembly lube do the trick? I run Mobil 1 in all my late model vehicles however I am leaning towards a quality dino oil for long term use in the Bronco.
broncnaz
Assembly lube and proper breakin procedure should do the trick. You'll have plenty of good wear additives for that break in with the assembly lube. Id save the higher zinc oils for down the road after that first oil change. Higher zinc oils are a good idea for a longer lasting engine but standard oil is still fine. Bascially run what your comfortable with.
bludorbronc
Don't run a stall ,need as low a stall as can get,on road and off.gear ratio and tire size affects things also.what rpm you run going down the road also affects cam selection..
wildbill
Old Bronco Guy
%)%)%) If you need to do a cam change talk with the cam co. you are going with and tell them what you have and what you want from it they can suggest the cam's that will do what you want and good luck.:p:p:p Bill :D:cool:;D
rguest3
You will be happy with the XE262H Cam.
Rotella-T 15w-40 is what I have used for engine break-in and what a few engine builders suggest as well. NO problems so far.
