In your opinion how much difference would the XE262 grind be? Idling rpms?
The crower Baja beast cam that I'm running with a NP435 manual idles nicely at 600-700 rpms.
I don't foresee major differences in idling - the XE268 will probably be a bit more choppy due to the duration numbers. The bigger difference between the two camshafts will be in the performance power band ranges.
The 262 is a more tame street mannered camshaft that will have less / different requirements of other components. I don't think the 262 requires a converter change for example (??)
You need to try and visit the website - read what the manufacturer says about both and look at the various components required with each.
A small disclaimer on this whole thing is: what works for me might not work for you. It might not sound or perform the same from one motor to another. All of my statements are based on how mine acts, idles and performs with my setup and assembled by me.
As I said in a previous post, any of the cams from 260ish to 270ish duration should perform well on the street. You just have to make sure that when you pick THE CAM, you also purchase all the other various components that compliment the cam - any short cuts and purposely non-matched components will spell disappointment to you.
that includes but is not limited to: valve springs, lifters, pushrods, timing set, headers, intake manifold, correct carburetor CFMs, converter and so on.
All I'm trying to point out is this: if you choose a specific camshaft and then go against the manufacturers suggestions - you can't really complain about the cam. The cam is definitely not a stand alone item and is only as effective as the rest of the components that are related to it and help it function.
I'm sure you'll pick the right one and do a fine job and will be proud of it in the end. Research is free, take plenty of time for it in the front figuring it all out before you start buying parts.
Comp Cams and Lunati have technical phone numbers and will tell you exactly person to person everything you want to know about proper packages and suggest the right cam for your specific needs - its what they do everyday and get paid to do, take them up on it. Get a pen and pad out and make yourself some notes and call those guys up.
Good luck
DJs74
