As the others have said, very likely at least a little rust.
I would, even as a general practice for an engine that's been sitting, spray some sort of good lube into each cylinder to keep things clean and smooth while you're just rotating it by hand and it's not getting any oil splashed up from running.
I don't know what the best lube would be, but even something like WD-40 would be better than just dry cylinder walls.
Better still if it was something that was thicker and left a film. But again, anything is better than nothing.
New pertronix distributor doesn’t have vacuum advance. Going to fitech- did I buy the wrong one?
Don't know yet. Which Pertronix unit specifically did you go with? Got a part number?
And are you planning to have the FiTech computer control the ignition timing? Presumably so, since you went without a vacuum advance.
But if you're not going that way, then there is almost no such thing as the wrong distributor, since the FiTech is only worried about fuel if you're not letting it run the timing.
I say "almost" no wrong distributor, because just this week someone was having trouble with their new installation and it turned out to be a multi-spark distributor with all that fancy stuff inside the distributor rather than an external module. Not sure what the dealio was, but perhaps it was a simple RFI issue.
But either way, let us know what you've got and how you intend to use it.
