I now remember seeing it on the camshaft data sheet...it reads:
13726548
Now the question is, which cylinder is which? Do the numbers follow the same flow as the diagram above? So 1372 is front to back on the passenger side and 6548 is front to back on the driver's side? I'll call the cam grinder tomorrow.
the cylinders stay the same always. firing order is just what it says. the order they fire in. it can start anywhere on the distributor, you just have to go in the right order after #1
Got it, thanks. This all came about because I'm starting the process of gaping the rings for the new pistons and I want to keep track of exactly which ring I gap in which cylinder and assign them to each piston.
