Rocky04
Hi, I do have/had some issue with my 351W.
When the motor was warm it started running crepy at idle. If I shut it off I had a hard time to start up again. I checked the spark plugs but there are ok, I cleaned the Carb. did not really change anything. I connected an vaccum gauge and it showed late timming. I adjusted the timming via vaccum gauge and checked it with the strobe light and it's around 15 dec. advanced now.
Now I have the felling the motor runs to hot, even the water temp is normal.
Other than that, motor runs great, response, torque, all way better than before.
Is there anything I should check?
