351W EFI plug recommendations
Timmy390
Conway, AR
Finishing up my 351W build and not sure what plugs I should run.
96 351W from a E350 Van, .020 over, stock Van cam, 8.8-1 compression, E7-P heads with GT-40 lower (cast iron version) GT-40 upper (off 96 Explorer). I'll be running a 94-95 Mustang ECU.
Right now I have the black remote mount TFI but I may run the gray as it might work better with the Mustang ECU.
So should I run the Van plugs or the Mustang plugs or other?
Tim
KyleQ
Van - you are using van cam and heads. If you were using GT40 heads I would say use the Explorer plugs.
