351w, gt40 explorer efi, stock hood.
Neil74&75
Hey all! Trying to explorer efi swap my 351w and keep the stock hood with no ,ore than 1” body lift. I’ve read a lot of previous posts but haven’t found the answer yet. One states that the tubular gt40 upper is 11/16-1” inch lower, but that is not what I’ve found. I’ve looked at buying a few different ones and they’re all right at 6” tall flange to top of TB flange. Anyone successfully done it?
Thank you for the help.
SteveL
Huge chevy guy
Hawthorne ca
I'll be watching this. My q-jet has never let me down but I have a spare 351w short block in the garage. I also fell into a 351 lighting lower intake on the cheap. My 72 has a 2" body lift and going back to a stock hood.
Viperwolf1
electron whisperer
Can't be done with only 1" body lift unless you do something to lower the engine another inch.
ngsd
I couldn't do it either. I ended up changing the hood. I like the look so it was not a problem.
N
Neil74&75
From what I’ve read and seen, you shouldn’t have any issues if you have a 2” body lift.
Green_Bastard
I went down the same path and couldn’t do it without a 1” body lift and slight modification to the hood while retaining a stock hood look. Nobody even notices the mod unless I mention it
N
Neil74&75
What was the hood mod you did?
gumby77
yuma
I installed my 351w without a body lift and stock hood by modifying the cross support for the hood so the air cleaner would clear.
Using the sniper efi and the 1 inch air cleaner drop plate. ALos had to mod the fire wall on the driver side to clear the valve cover.
