351W Firing Order???
broncoP
Just finishing a frame off and trying to get the 351W to fire. After hours of following and changing wires, i finally have spark to the coil and fuel getting to the carb. Believe it is a 84 351W, i'll have to double check. I've looked at some charts that show 302 and 351 as being the same, but i know they are all not the same. I had a 289 with 351 heads that was 351 firing order. Anyone know if all 351W's have the same firing order ,or what years are different or any good links.
Don't ever build a bronco from scratch, way too many headaches
SaddleUp
Vancouver, WA
302HO and 351W all had the same firing order.
289 and regular 302 all had the same.
It is mechanically possible for either to have the opposite cam swapped in to change it. For your 289 to have the 351W order it had to have a cam for either a 302HO or 351W swapped into it. (It doesn't have anything to do with the heads)
