I've only had this truck for a couple months and I've finally decided to dive in and get some items addressed now that the heat is rolling in to AZ. Long story short, here is what I've discovered with the motor.
I ran a compression test yesterday, all cylinders were at 120-ish psi.
Spark plugs are fairly black, some with oil on the threads.
It also puked a little coolant the other day(temps were in the 80s). The PO had an anti-freeze bottle jammed behind the grill as his catch/overflow can.
It doesn't have a functioning temp gauge (yet) so I'm not sure how hot it's running. When I initially got the truck it seemed to smoke a bit out of the exhaust pipes but that has seemed to go away for the most part.
What would be the best course of action to address the black/oiled plugs and correct the coolant issue? I've got some assumptions of my own but I thought I'd ask the experts and try and come up with a good plan of attack to get this thing in better shape. If you have recommendations for specific parts/items I'm all ears. I apologize if I've left out any important info but I can take a look at the truck so let me know what you need. I appreciate any feedback.
