351w Oil pan question
tasker
all knowing of nothing
NH
i've used the crown vic 351 pan in two trucks now and no clearance problems thus far
bigmuddy
Marthasville Missouri
So somewhat of a different although relative question.
I installed a pan out of what I recall from a big bronco on a rebuilt 74 block with the dipstick hole in the block.
I was planning on installing a lokar flexy dipstick but they don't sell one for the block application, only the pan application. I have yet to find a solid metal "stock" dipstick that will work with my shorty headers so I ordered the WH pan and pickup to then run the lokar flexy dipstick.
I would rather just run it as is but don't know what to do about the dipstick so I am likely going to spend afternoon swapping the pan...
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
Do you have any photos of the modified pan? I have a Canton deep sump pan on my 351W stroker. They market it as being an early Bronco-specific pan. It also has a cutout at the left rear corner for clearance, but it's not enough. With the suspension compressed the front driveshaft barely clips it. And they don't fabricate the pan from scratch, it appears to start out as an aftermarket copy of a rear sump 351W pan. Not a great one, the drain ports are poorly made with a rough sealing surface so they leak despite fresh copper washers etc.
I also have a dented Ford Performance, AKA Panther pan, and the corresponding oil pickup tube. I could use it as the donor for the rear saddle. Tempting to make my own "Duffs" pan. What oil pump pickup tube are you using?
Lars, I’ve been running the Panther (Ford Performance) pan on my 351 and 408 since 1995. It works just fine. I did end up using some stiffener rails from the E-van I got my most recent block from, along with the 1-piece pan gasket, and get zero leaks. The front sump got clearanced a bit by the track bar when I was running a factory front axle and track bar riser, but everything clears perfectly with my new suspension setup.
tasker
NH
i used e-250 dipstick and tube....installed and measured where the oil level was....no problems yet!
rocknhorse76
Central WA
I used a small brass plug in the block dipstick hole of my ‘94 roller block, and use the Lokar dipstick in my Ford Performance pan (basically the same pan WH sells). I also have shorty headers on mine.
bigmuddy
Yep, thanks thats my plan but was hoping for an alternative to pulling the pan off.
lars
Been here awhile
NorCal flatlands
You might try looking for an Explorer 5.0 dipstick. My engine had a block-mounted dipstick. The depth might be wrong, but you can probably fix that by tweaking the length of the tube, and possibly bending it to clear as needed. The nice thing about the Explorer dipstick is it's twisted rather than flat, so it can handle a tube bent in 3 dimensions. The Canton pan is set up for a pan-mount dipstick so that's what I'm running. I made my own tube and I'm using the Explorer dipstick.
lars
Been here awhile
NorCal flatlands
Ok, good to know. I won't be swapping anything anytime soon, lol. Still need to recover from all the recent work I did.
bigmuddy
Oh and another thing, Lokar told me the reason they don't sell a dipstick for the block mounted dipstick on the 351w is the dipstick comes out right under the crank, and since it's flexible whips around and contacts the crank..
jckkys
I wish I had taken photos with the pan out of the truck. Now looking from below, the pan simply looks like an EB 289/302 pan. In fact, few knowledgeable EB or Ford small block (gurus) can see there was a 351W swap. There is a vague feeling it looks wider and the added distance above the water pump to the head gasket, that gives it away. I always look there, but only because I know the other indicators are gone. Sadly Ford could have done this far easier in '69, but they had little interest in updating EBs. I think they saw Broncos solely as a farm/ranch implement. I want to reiterate that the EB small block pan is the ONLY one designed to work in the EB chassis. The others are will hit the front axle at full compression.
