Figured since I'm puling the pan and have put a High Volumn oil pump in I'd replace the pump drive shaft. Should I use a Ford Motor Sports or Melling? What do u guys think?
I used an ARP drive for mine I think the ford motorsports is the same I dont know about melling but as long as its the heavy duty type Id say your good
Anything is better then stock. My 351 runs a motorsports, the stroker 302 (non-bronco project) is getting an ARP. They are both running Melling pumps, HV and standard.
no, i don't have paypal, so i guess you could send a check. melling makes a good pump, i've run them. i just don't see the need for a hv in my rig. i'll pm you my mailing address.
Make sure the HV pump clears the 351 pan. I had to do some grinding on the pump to make it fit. Some of the ford pump drive shafts vary in length. I run A dui dist and they recommend an aftermarket pump shaft cause the stock ones tend to be too long.
