351W options.
michael084
Santa Rosa Beach, Fl
I am trying to decide the best route to go once the funds are available (probably after summer). There is this http://store.summitracing.com/partd...294925232+4294918831+400070+1011&autoview=sku
which seems like a great deal. All I need is body lift and oilpan and already have a carb and flywheel.Would the waterpump have to be changed? Then there is the option of buying an ATK rebult from carquest and putting these heads on it http://www.tristatecylinderhead.com/tripro.htm anyone use these heads? Seem pretty cheap. Maybe the edelbrock performers would be wiser. If I do the ATK I still need to buy an intake, distributor, oilpan, bodylift, waterpump, etc. What do you guys think?
broncnaz
The ford crate engine is a decent deal but if your swapping cylinder heads why get a long block? get the short block its about $1000 cheaper. you'll need an oil pan, intake, dist, but the front timing cover, water pump, Harmonic balancer and assesories can be reused off your 302 just get the adapter brackets for the accesories.
While I've never heard of those heads The specs look good I'd try to find out a little more about them like whos casting them. For the price they should be worth it. Also you will need new pushrods if you go with them heads they will need to be longer and hardened for use with guide plates the company selling the heads should be able to tell you the size you need for your combo. If they cant tell you this then I would be wary about buying them.
M
michael084
After doing the math it seems that I would be spending about $300 dollars more to build the engine from the short block using a Ebay HEi distributor, camshaft,peformer intake, and those heads. Both would need an oilpan, and body lift. I am going to try to find out more about those heads on some mustang sites and see what kind of reputation they have.
70_Steve
Old Guy
I think... it would be a help to know what kind of use the Bronco will be seeing. If your Bronco will be seeing lots of dune running, jumps, etc. then maybe the high rpm capabilities of the Ford Racing engine would make it worthwhile. If you plan on some rock crawling or general trail driving, then, with the Ford Racing engine, you're probably going to be paying for stuff you''re not really going to need. I've always been leary of the "remanufactured" engines available at the auto parts stores. A very reputable machine shop quoted me $1400 for a complete rebuild. That included all machine work, all new wear parts with Clevite bearings, valve work, cam of my choice, etc.
Also, those heads you're looking at have oversized valves. Again, if you're not looking for high rpm capability then those might not be the best heads. If you just gotta spend money on heads, then the Edelbrock Performer heads with the 1.9" intake valves would be a better choice for low rpm torque. Actually you'd probably get just as good performance if you send the stock heads out for a mild port job, and maybe a slight mill to raise the compression up a bit.
Do a little more research on the 351 swap. There's more to it than just a body lift and an oil pan. Not much more, but you really do need to plan what you need to do.
M
michael084
I don't think I would call that a racing engine, it only has 250 hp , it's a truck engine, the main reason I am considering it is because it is new not remanufactured,the place with the heads sell all kind of ford heads they have gt40 heads for about 500 dollars. There doesn't seem to be any shops around me that actually rebuild engines they just get crate engines, it's like trying to find a body shop that does restos around here there aren't any they all want collision work with insurance money. I go to school 4 nights a week and am working 6-7 days a week right now so I am trying to save time by not rebuilding myself, never done it before either but I am pretty sure I could. So 70 Steve with your advice about the heads i think I will go with the Summit engine long block it is the lowest cost of the options am looking at. Thanks for all the replies.
sbingham2
Cedar Park, TX
I just ordered the Ford Racing 351 last week, I'm supposed to pick it up from Yellow Freight on Monday. After looking around it seemed like the best deal.
In preparation, I already picked up the oil pan kit, water pump, harmonic balancer, headers, and various conversion brackets. I didn't opt for the body lift, but instead threw on a Pro-Flow hood and a Lokar throttle cable to help with the clearance issues (I hope).
I'm planning on taking photos and notes while I do the swap, unless I get too frustrated at some point and decide to stomp on my camera.
Since I'm throwing in the same exact motor you're looking at, I would be happy to pass any info or photos your way. Same goes for everyone else out there.
M
michael084
That would be awesome ,thanks. Any info about how much it ended up costing total would be good too. Did you get it from Summit? Is there any warranty? I can't find any on their website.
NYLES
Get up with me Ill help you with your motor......figure out how much you wanna spend and how much motor you want! Id guess $2000-$2500 and some of the parts off you motor and Ill have you breaking things! What I think you need is a short block with the right cam and some heads.......Youve got alot of the rest if not all of it.....only thing I REMEMBER that you need is an ignition.....call me Sat do your homework brtween now and then (motor stuff) WE WILL COME UP WITH ONE BETTER THAN THIS ONE>>>>>Oh I believe those tri state heads are reman if they even got em I didnt come up with anything I like from them if its the same place.
sbingham2
Cedar Park, TX
I was planning on picking it up from Summit, but when it came time to order they were out of stock, so I went with Jegs. The price varied by only by a couple of dollars. The total with freight was $2995.
Ford Racing's crate motors come with a 12 month warranty. Here's a link to motor on Ford Racing's website:
http://www.fordracingparts.com/crateengine/smallblock.asp
I'll post some photos and initial impressions once I pull the motor out of the crate next Monday
broncnaz
$300 more is not bad considering aluminum heads are worth at least 40 extra HP. You cant add 40 HP for much cheaper than that. I wouldnt worry too much about the valve size on those heads your running a 351. I'm running TFS heads on my 302 and it runs fine with the big 2.02 valves I didnt notice any loss of low end torque although my stock heads were pretty messed up so it wasnt up to power with them anyways. But if I did it again I would run 1.90 valves on the 302 as they are probably big enough.
john32
i have a 71 Inline6 eb. what would be the best way for me to go with a 351w swap. i want to spend 2000-3000 $.
sumpunker
Cincinnati
I was thinking about doing the same swap from the 302 to the 351 other than the carb oil pan kit water pump and harmonic balancer is there anything else i should get for the swap ill be having someone do it for me cause im not and engine guy and what will the extras run me thanks
ElJefe
San Diego
Actually it's either a marine engine or an industrial engine with the full sump pan. Won't make any difference as long as they put in a truck cam. I would check to make sure that the FMS folks put a truck cam in it. The marine cams are only good up to around 3500 rpm. OTOH... the marine cam probably would make 300+ ft-lbs of torque at idle!
