351w throttle linkage problem
Waxmaster
Southbay, California
I just swapped my 289 for a 351w. I am ready to hook the throttle linkage back to the accelerator pedal and realized the valve cover won't allow it. Does anyone have an easy solution for this problem? I have heard some people say a body lift will fix it. I would rather not do a body lift though.
I did mine by bending the linkage. Some of the venders (I think I last saw it in the Duff catalog) sell a revised bellcrank for the 351 swap
SHX669
I've done both .
Bent the linkage and install a shorter bell crank.
SHX
W
Waxmaster
I think my valve covers may have something to do with it. I have the edelbrock aluminum covers which are a little taller than most. When I muscled the accelerator rod through the firewall it wasn't moving more than a 1/4" inch and scratched the valve cover pretty good. If i bend the bell housing will it still have enough movement?
wildbill
Old Bronco Guy
%) %) %) I just fabed a rod from the firewall to the carb did away with the bellcrank works good and has been working for 36 years now good luck. :D :D :D Bill %) :cool: ;D
