3G conversion wiring diagrams
Viperwolf1
electron whisperer
The 1-wire instructions are for use with a 1-wire alternator. If you don't have that use the other instructions.
badandy73
Broncoholic
Just went through this after my 1-wire finally gave out after almost 10yrs. Picked up a 3G from autozone pn# 7734-6-11 (94 mustang) and hooked it up same as my one wire. Alt. wasn't getting a signal to excite and therefore wasn't charging the system. Re-read my painless manual and bought napa pn# VRC441. Hooked it up accordingly, large yellow/white to constant 12v(BC's shows this looped into charge cable conn. instead of fed from the harness), white/black looped back into stator connection on back, green/red to switched 12v. Hope this saves someone the frustration I went through.
bronconut73
bronconut73
Thank you for the Napa part #VRC441.
Went there today and grabbed it.
bronconut73
bronconut73
See attached photo.
According to the BC wiring diagram the green/red wire off the 3G Alternator wiring harness needs a 12 volt (run) power wire.
After I remove the (stock) "old" voltage regulator from the fire wall will any of those wires from the (stock) "old" alternator wiring harness still work?
....Can I pick up a 12 volt/run power wire from that original alternator harness after I remove the old regulator...?
Also....
How do I unhook the amp meter so it doesn't cook from the increased amperage?
bronconut73
bronconut73
Bump.....
I know we've discussed this....just didn't see this specifically,
For example....I know the amp meter will not like the 3G....just not sure I heard what we do to fix that. I already have an Autometer Volt meter, just never unhooked the amp meter.
Also...for example,
I know there is a 12 volt/run power wire in the stock '73 alternator wiring harness but I am not sure it Will still be hot when I remove the oem voltage regulator....
Thanks Guys.
I love this bar....
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I just did this using a Painless 3G alternator harness. Three wire plug - white and black goes to the single plug on the alternator. Green and red off of the three wire plug goes to the green and red wire that used to go to your voltage regulator. Yellow wire off of the three wire plug goes to the yellow wire that used to go to your voltage regulator.
I have no idea in your picture why you have a wire from the three terminal plug going to the power hookup. Every 3G wiring diagram you can download shows that being a 6 gauge wire hooking to the battery with a mega fuse. Even in the stock Ford applications that was a 6 gauge power wire. A wire from the three plug connector DOES NOT connect there.
Look at page 4 of the Painless instructions below
  • 3G.pdf
bronconut73
bronconut73
I have a 4 gauge wire for that spot.
But the BC diagram shows it that way.
It wouldn't let me save the image the other day but they have two....a one wire and a three wire diagram.
bronconut73
bronconut73
This is that BC diagram.
  • 3G 3 wire with water mark.pdf
bronconut73
bronconut73
Do I need to do anything to make sure my amp meter doesn't cook from the increased amperage.
At the bottom of the BC diagram referenced above there is a note with a line pointing to the starter relay. Wondering if there is a wire there I will be removing? and if I do will it effect anything else?
Sorry...my eb is a little tore down right now or I would just go by trial and error, but can't crank it right now.
Justin has me straightened out on the 3G wiring now.
I just do not want to smoke test my dash wires because the amp meter cooks.
Viperwolf1
electron whisperer
See attached photo.
Also....
The hot-in-run wire you need will be going to the old voltage regulator plug. It's not really in the alternator harness, it's in the body harness. It's the green-red wire. Connect this wire to the green-red wire at the alternator plug.
You will need to do something with the old alt charge wire (10g black or black-yellow). It is connect directly to the battery (always hot). You won't be using this 10g wire path for the 3G because it will cause a fire. The 4 or 6g wire in the BC diagram replaces it and sends the alt current directly to the battery. You can connect the old 10g wire to the battery side of the starter solenoid but you should use a fusible link on it. Just having it connected to the battery doesn't mean it will be carrying significant current like the alt wire.
Your ammeter will no longer work after you install the 4 or 6g wire.
The purpose of the yellow wire is to measure battery voltage. It tells the internal regulator how much to charge. It doesn't matter much if it's sensing that voltage at the back of the alternator or at the starter solenoid, as long as all the wiring is good and short.
bronconut73
bronconut73
Up late tinkering on the eb.
It is so nice to look over and see my Buddies Viperwolf and thegreatjustino hooking me up with the wicked eb knowledge....
Yea...I'm tired...
Thank you Fellers.
Steve83
You follow that wiring diagram I posted.
...I am not sure it Will still be hot when I remove the oem voltage regulator.
If you follow that diagram, the necessary wires will work correctly. If you want to understand why, compare it to the stock diagram which is linked in that one's caption.
If you ran 1,000A through it, it might damage it. But you can't because its induction loop isn't big enough for an insulated wire large enough to withstand 1,000A. So the meter isn't the issue - it's the factory WIRE that passes through the meter's induction loop that's the problem. That's why it MUST be eliminated from the alternator output circuit, and replaced by one that can handle the 3G's output. All you have to do is what that diagram shows...
The ammeter is independent of the other gauges - no matter what happens either way, they don't affect each other. But since it's an inductive ammeter (as opposed to a full-current ammeter), it doesn't carry the load that it's measuring.
bronconut73
bronconut73
You follow that wiring diagram I posted.If you follow that diagram, the necessary wires will work correctly. If you want to understand why, compare it to the stock diagram which is linked in that one's caption.If you ran 1,000A through it, it might damage it. But you can't because its induction loop isn't big enough for an insulated wire large enough to withstand 1,000A. So the meter isn't the issue - it's the factory WIRE that passes through the meter's induction loop that's the problem. That's why it MUST be eliminated from the alternator output circuit, and replaced by one that can handle the 3G's output. All you have to do is what that diagram shows...The ammeter is independent of the other gauges - no matter what happens either way, they don't affect each other. But since it's an inductive ammeter (as opposed to a full-current ammeter), it doesn't carry the load that it's measuring.
Good Stuff Steve!
As always, THANK YOU.
Love this bar.
bronconut73
bronconut73
It started at 12.2 volts, after about 4 minutes of idling it was at 14.20.
So it's charging...
Thank you guys for all the responses.
Steve83
Viperwolf
And my favorite used parts supplier,
The Great Justino
This place wouldn't be the same without you fellers.
bronconut73
bronconut73
Horrible belt squeal though...
Sigh.....
Working on it...
Update.
Quality belt (important).
Properly adjusted.
And all you hear is a slight chirp when cranking it.
Once started you "cannot" make the belt squeal now.
One thing that helped was I hit up eBay for a nice heavy duty alternator pulley. It was even sort of rough where the belt makes contact.
No need for double pulleys/ belts.
Very pleased. Super good charging.
Fans spin faster at idle, lights are brighter at idle, etc...
And I had no issues with any of these items they are just noticeably improved.
For some reason the eb turns over faster too. Fired up quicker as well.
I think some of that "removed" stock wiring was hurting me and I didn't know it.
Anyway,
Very happy.
Highly recommended.
Cheap, powerful upgrade. Well worth your time.
