3g: Small case or Large case?
valveamp
Hi. I'm about ready to pull the trigger on a 3G alternator conversion upgrade. The question is, as for fit, do I need to get a small case or can I fit the large case 3G alternator? What can I do with my existing brackets? I have a stock externally regulated alternator now. Thanks.
cs_88
The small case may be the better fit, but I'm running a large case 3G with stock brackets no problem.
Airmapper
Foolproofness Tester
Bowling Green, KY
A Large case will fit, mine is mounted high with what I think are stock brackets arranged to put it up at the same height as the valve covers.
I'd go with the large case, it puts out 130amps, the small case is 90amps I think. Either is better than stock though.
Toddml
Small case is 90 Amps, Large case is 130 Amp. Large case fits no problem. The other item that comes up is the spread between bolts, one is 7" ish from the mounting hole to the adjustment hole, the other is 8 3/4". Both fit with out any issues, may need a belt change with the wider spread.
pcf_mark
I used the larger case one also. All I needed to to was grind the factory bracket a little (plus the minor wiring). In my top 3 mods ever.
Rustytruck
If your motor has the heavy cast steel smog pump brackets and you want to keep them then your stuck using the small case.
