Thanks for the input guys. My main goal is to gain a little more power and gear options to make it better both on and off road. I have started driveing it more and more as a daily driver insted of just a weekend toy. I have looked into some performance options for the 200 such as a cam, header, and machineing the head to accept a 2bbl carb, then possible putting a 5 speed in it,but i'm also looking for cost effective. Like was mentioned before, I have this motor here and....
- Rulebreaker; it is a '92 pushrod 4.0, thanks for the info on the adaptor also but one of the goals of this frankenstien idea is to gain an overdrive and 2 more gears useing the 5- speed ranger tranny.
-Broncobowsher; thats a good point, havent considered the height issue yet but will check on that. Fabbing up the mounts and cross members is kinda exciteing to me especially since this swap hasn't been done except for a time or two maybe.
-Broncnaz; Being a 6 cyl. Bronco it came with 4.11 gears, and luckily both diffs have the factory trac-lock limited slip that seems to work beautifully.
I had a '92 Ranger years ago with the 4.0 and it seemed crazy fast. of course it was a 2wd, short bed, regular cab, 5 speed so the power to weight ratio was a bit different than an EB.
