411 or 350
gg9330
I'm new to the forum, thinking about switching out my transmission to AOD and switching from 350 to 411 gears. Whats the difference? Does anybody know of a good shop in los angeles to do the work?
The difference is acceleration from a stop and highway cruising RPM. Knowing nothing else about the Bronco or how you plan to use it, that is about the only answer I can come up with.
What engine do you have (or plan to put in)?
What size tires are you running on (or plan to change to)?
How will this Bronco be used? trailer queen trail rig, lots of highway, just around town, etc.?
I have doubts that 4.11 gears will be low enough with the overdrive. Unless you are running stock 28" tires the gearing will make it a dog on the highway, always shifting in and out of overdrive on every hill. But I can't recommend a gear that would be better since I don't know anything about this Bronco.
Next is the choice of AOD. It really isn't that great of a transmission. The 4R70W is the modern choice. Bone stock it was built with more and better upgrades than what can be put into an AOD. The downside is it needs a stand alone controller, the upside is the overall cost (even with the controller) is generally less then getting an AOD and throwing upgrades on it. The 4R70W has better gearing, better torque convertor (selectable lockup), and has tunable shift points. It has become a more popular swap then the AOD. Strongly suggest you look into it.
spap
A lot depends on the tires size you are runnijg too, the good thing about the AOD is you do t have to buy a separate controller $575 to run it .but the 4r is much stronger. The AOD has a .68 over drive so you could go to 4.56 gears min. Anything else you will be lugging the motor unless been built and has a lot of torque the AOD was fine in a lot of big broncos mustangs and vans. Just not the best
399strokerEB
Wasilla, AK
I run 4.56's but I'm running 37's, engine is a basically stock 351. It all depends on what your engine is and what size tire you have.
bearskinner
N.Idaho, AK, SoCal
You need to look at what you want to END UP WITH. start there. too many people change gears, than start changing everything else, and end up changing the gears again. stop, look at all options, tire size rpm of your motor, transmission, than plug it all in to a calculator of how you want it to drive. do you drive hwy, or only off road? no one combo can do it all
When doing calculations, remember it is a heavy, aerodynamicly challenged, 4WD with lots of rolling resistance. It's not a mustang, it won't idle down the highway at 70 MPH at 1500 RPM. You are fighting drag and lots of it, you need some RPM to get the leverage to win the battle.
blubuckaroo
Grease Monkey
Ridgefield WA
All good points. I'll add that you also need to consider the first gear ratio. A car that's got a first gear that's too low or too high is no fun. For example, the first gear ratio of a 3 speed and C4 are pretty high and need a lower differential ratio, but that of a NV3550 is pretty low and is happier with a bit higher ratio.
ahansen_1985
amity, oregon
As these guys said a lot depends on what you want to do and your motor... Even if your a built 302 I would not run a 3.50 overdrive with anything bigger than a 33... Even at that you'll most likely feel underpowered...
That being said mine is a daily capable, wheeler... I run a mildly built approx 375hp, 351w, c6, full widths and 37's 3.50 gears and love it...
Bit we all have our own taste.... And different power setups
blubuckaroo
Grease Monkey
Ridgefield WA
I just think too many select the ratio with regards to the highway performance alone. I've found that most engines are more forgiving on the highway than in the lower ranges.
