411's vs. 456's
olybronc
olympia
Am I better off using 411's or 456's for 36" tires? Also, anybody know if the bb 9 inch is better than the sb-I have the sb should I go looking for the bb unit?
Mr Joe
I'd opt for the 4.56. It really depends on what you use it for mostly.
The BB has many more options for upgrades than the SB.
broncnaz
4.56's or 4.88's are recommended for 36in tires. A big bearing rear end would be a lot better with tapered wheel bearings because they can take the higher side loads of your bigger tires
Nobody
Stanwood
I had 4.56 and 33's, then I steped up to 36's. I definately lost a little spunk, but 4.56 and 36's is good all around combination that I'm happy with.
Blue71
For street...4.56's should be fine. For the trail/ street ...I'd go with 4.88's. I run 4.56's now with c4 auto tranny and it is great on highway, but could use a little lower gear like 4.88's on the trail.
With 36" tires...I think you could get by just fine with 4.88's if you wanted as well.
Blue71
rednck21
if you dont do much interstate driving id go with the 4.88's.
my dad has a complete bb 9" from a 76 for $300 if your interested ;D
joser
Chesterfield, MI
I put 4.56 in mine last year and run 33". I wish I went with 4.88. With the 4.56 gears I still was able to do 80+ on the freeway with plenty RPM to spare.
RajinCajun
HawleyTX, La orig.
I also vote 4.56's...I am running 4.11's with 35's, but plan to upgrade to 4.88's or larger...depending on what I can get for my D44..or I may be upgrading to front/rear D60's....
