I have a 72 with a 3 1/2" lift,c-4,built 302.I drive on the road and off road 50/50.Have 3.50 now.Also detroit in rear.4 high in 2nd gear bogs bad in the sand until I get speed up.2 high and 4 high good to go.
If you have 33" tires then 4.10's will work good, For 35" tires 4.56's will work good. For sand or a lot of highway/freeway driving you could get by with a little higher but on the trails and normal street use these will work well.
4.10 is great for a non-overdrive 33" tire. Quick on the street, torquey on the trail, still has long enough legs to get down the highway at speed for longish distances. Personally did 200 mile each way road trip with that combo comfortably. Know others that are the same way.
4.10 is a bit doggy with 35s
Never tried 33's with 4.56. But they do screem with 4.88 and not in overdrive.
It isn't too horrible. My father-in-law runs 33s and 4.56 w/ C4. She is singing a bit on the highway, but around town and on the trails, it is great!
I would say that if you don't do much highway/interstate stuff (or you don't mind singing your motor a bit), go with 4.56's. Then, if you choose to jump up in tire size down the road, it won't be that big of a deal.
GJrock, I have a C4 & 4.56's in mine w/33s and its tough going on the hwy at speeds above 60+. If you plan to go with overdrive sometime in the future then get the 4.56s, if not then 4.11s are good compromise.
I have run the 4:11's with 33's and it is a very good setup still running it. Try it you will like it We had one with the 4:56's it worked offroad real good and in town it was good but on the hiway they were to low. Good luck with your choice. Bill %) ;D
