Beautiful wiring job Mike. Are you making your own?
The cable routing (mostly!) and the quality of the ends looks great.
But looking again at your starter relay I'm curious. Can you take a wider shot and give a rundown of what is connected to what?
I assume you intended to connect that ground wire from the alternator to the starter relay's attaching screw instead? Even if not, that's where it should be. And NOT connected to either the battery's or starter motor's power lead.
And speaking of the battery, which side are you planning to connect it? Usually it's on the left side stud in your pic, where I now see a Black wire that looks like a power feed to something?
What's that other wire connected to the same side that your alternator charge wire goes? Is that the battery or starter?
If the battery is on the left and the starter on the right, then as soon as you turn the key to START you will have a nuclear meltdown on the wires.
And if things get past that and the engine starts, the alternator will keep the starter engaged permanently until you disconnect the alternator.
Maybe I'm seeing it wrong, but those are the things that concern me and I wanted to bring them up.
