- Oct 11, 2007
- 564
So I’ve just recently had a 4r70w built by a guy that I’ve known forever and he used to be the transmission guy for our local ford dealership.
The transmission shifts fine BUT occasionally when I take off from a stop and give it some extra gas the trans acts like it goes into neutral and as soon as I back off the gas it takes first gear and shifts all through the gears perfect.
I ran a key on engine running test with my scanner and got range sensor out of specs. Drove it around all day the next day and zero issues. Today I decided to adjust the range sensor by aligning the two lines while the trans is in neutral. Not sure if that’s actually how to do it or not. Drove it to town and it did it again at one stop light but only once. Anyone have any idea what could be causing this? Pic is of the two lines I’m referring to on the sensor
